jentor
Oct 09, 2024Explorer
Hi Doug have same short cycling issue with my rv furnace high temp limit cycing. if I keep the outside air door open it will run all day. outside and return air ducts are not restricted, curious if installing an additional heat duct under cabinet would fix air flow and exchanger cooling.
way2roll
Oct 10, 2024Trailblazer
hi, you are responding to a post that's 3 years old and Doug (unfortunately) hasn't been on here since the new forum was implemented. I suggest you post your question in a new topic to get responses.
