Old-Biscuit
Sep 19, 2020Explorer III
Gas Valve is NOT adjustable
Gas pressure is controlled by Main LP Regulator
Orifice meters the flow of gas
How did you clean the orifice?
No poking anything thru it OR blowing high pressure air thru it
THAT will damaged the laser cut meter hole
Orifice should just be soaked in alcohol and air dried
Overheating can be result of damaged orifice
High LP SYSTEM Pressure
Blocked Combustion Exhaust
Blocked room air return
Ducts collapsed, blocked or too many registers closed
Room air wheel missing vans
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
