jsuvman's avatar
jsuvman
Atwood 8531-IV-DCPL Furnace
Have an older 1999 RV. Tested furnace last week when the temps at home got down into the low 20’s. Everything was working fine. Just arrived in Indiana and went to turn it on last night and it is lighting but then shutting off after the 6 second flame detection time. As you know it will do this three times and then lock-out. This older modle does not have the LED on the circuit board.
I pulled the outside cover and checked all wire connection and all look good. Had my wife turn it on while I was outside and after it lights I can continue to hear the clicking of the spark. I figure this means the board is not detecting the flame and is still trying to light it. So here are my questions.
Do you think this is an electrode issue or a board issue?
Could it have something to do with the wire between the electrode and the board? If so, is there a way to test that wire, like can it be jumped out with a test wire just to see it that works?
Is there something else I can test by myself as I am parked right now at our daughters house.
Last, if I pull it all apart should I just install a new electrode anyway?
Oh, all other gas appliances are working OK and propane tank is full.
Thanks in advance for any help.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
