jjrbus's avatar
jjrbus
Atwood Air Command AC, anyone using?
I keep coming across this Atwood Air command 13.5 BTU which claims to be 2000 watt generator friendly, even shows a picture of it with a Honda EU2000i.
I read what I can find and the only LRA that is shown anywhere is 63 Amps. 63 A is way beyond a 2000i capabilitys.
I have read a bit where people talked about running one with the little Honda 2K but they do not go into detail such as temperature, humidity or elevation. I can run my 11K roof air on my Honda 2K when it is cool out, but will not run it in hot humid weather, even with a hard start capacitor.
Does anyone have any real world experience with these units or somewhere that someone with some knowledge has tested them?
Any input greatly appreciated. Jim
  • jjrbus wrote:
    map40 wrote:
    I have a small rental fleet and have installed 6 of them (5 13.5 and a 15K). Delayed start, digital control, furnace conection and remote control.
    The are great. The controls are years ahead of the controls you get from Dometic or Coleman. The will run on a 2000W and 2 on an Onan 4000. I wish I could change them all.
    During a web search I found your previous post about this, you are the only one that I can find that gives it a thumbs up on a 2000 watt genset that is likely doing it in hot humid weather!
    Thanks for responding. Jim
    One big thing to keep in mind, when I run them on a 2000W generator, the AC is the ONLY thing plugged into it. No converter, charger, nothing. We use the 2000W on the units we have the 13.5K as backup, so it is wired independently from the coach.
    I have one coach that the main AC is also a 13.5 Atwood, that one I have used a 2200W ryobi and it run with no problems without anything else, but the converter and charger were on.
    A 4000W genset (Onan or Generac) have been able to run 2 ACs, as long as one of them is an Atwood 13.5K. 3 motorhomes have 1 15K (other brand) and an 13.5K Atwood. They all run fine with the generators (I would not recomended for long, but in a pinch...).
    The unit with 2 13.5 Atwoods runs really good on a 4000W onan, with some power left.
  • jjrbus wrote:
    I do not know! I can point out that in their advertising only the 13.5 is shown to run on a 2000 W.
    http://www.tvformyrv.com/content/AtwoodACPresentation2014.pdf
    That is the reason why we bought them originally. The are not as cold as my coleman, but they move twice the volume of air. I have 2 identical motorhomes, one with 2 coleman 13.5K, the other with 2 Atwood 13.5K.
    The first coach can sometimes run both Coleman with the generator, but after a while it pops the breaker.
    The second can run all day long with both Atwoods on, no problem.
    I have even tested both units on shore power, the one with the atwoods coaled faster and colder.
    I have only had them for 1.5 years (the oldest one) so I can't comment on longevity, but so far they work great.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
