Old-Biscuit
Sep 09, 2015Explorer III
Atwood uses same set of t-stats for electric and gas operation since 2004 model year.
The XT uses 'higher factor preset' normal t-stat than the other models.
The normal is set to open at 160*F (vs 140*F other models use) and the ECO (Energy Cut Off/High t-stat) is set for 180*F (which is same as other models).
The higher heating temp is 'mixed' with cold water for a finally output temp of 130*F.....gives the equivalent of 16 gallons from a 10 gallon tank.
IF normal fails to OPEN and ECO OPENS it triggers 'Fault Light' (which also locks out operation). T-stats will reset (Close) when temps drop to 110*F but until fault light is reset no reheating will occur. To reset 'Fault Light' you turn On/Off Switch OFF then back ON.
With ECO operating......normal t-stat has failed OR is not tight against tank wall'
Inexpensive to replace....come as a set.
Atwood part number #91547 for XT Models LINK
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
