enblethen
Oct 19, 2020Nomad
colors appear to be correct with provided model number.
How does the stove top flames look? Turn on all and see if flame turns yellow. This is sign of bad regulator.
Check electrode for proper spacing.
Remove cover from the thermostat. check how many wires. If only two wires connect them together. Furnace should cycle on and provide heat with no shut down. Separate the two wires, furnace should go into cool down mode and shut down.
