enblethen
Oct 19, 2020Nomad
That somewhat rules out a bad regulator. If you had low pressure and volume the flame would have flicker with yellow flame.
At the furnace, locate the two blue wires on the terminal strip. Connect them together there rather than at the thermostat test as suggested in my other post.
The colors leaving the furnace should be the two furnace wires at the thermostat.
