BurbMan
Oct 20, 2020Explorer III
I was thinking there might be a damper or something inside the unit that would enable you to set how much air goes thru the ducts vs the main grille. I wonder if a piece of sheet metal blocking a portion of the main grille would serve that function and force more air thru the ducts? Or would the unit just overheat and shut down....
The t-stat is on the wall directly across from the unit, so when it comes on it quickly heats up the immediate area and shuts off. After a few minutes of natural convection with the hot air going up into the cabover area and the cold air flowing down, the heater lights again. So the result is a lot of short cycling. It got down to about 39* up in the PA mountains last weekend and it seemed like the furnace was only off for 2-3 mins before it would start up again.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
