enblethen
Oct 16, 2017Nomad
It could be a bad thermostat.
Remove the thermostat cover and connect the two wires together. the furnace should come on immediately and start producing heat after the time delay operates. This will be 10-20 seconds. If this happens separate the two wires. Burner should shut down and the furnace will go into cool down and then shut off.
Only reset on some furnaces is on the fan motor. Small red or white push button.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
