horton333
May 20, 2017Explorer
mikestock wrote:
5 to 1 odds that dirt dabbers are playing a roll. I have had lots of experience.
Well the answer is ... I removed the burner looking for critters, but I found this rusty burner. Enough rust that a good portion of the burner holes are plugged solid and that seems to fit the symptoms and I guess I can clean this up or get a new one ... BUT.
I can't really see much inside, without taking a lot more apart than I have, but where would all that moisture come from? It was a couple of weeks of a lot of heavy rain that proceeded the problem, and the box on the outside was very wet (but the silicone sealant seemed to all be intact so I don't think it got inside.\. The chimney seems normal, so it should not be getting in that way.
The moisture seems to have puddled at the bottom, so I guess it could have come through the propane - but that much water should have played havoc with all the other propane appliances and they all work fine.
Any ideas?
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
