ScottnDana's avatar
ScottnDana
Atwood furnace not igniting
We have a Jayco Jay Flight slx tt. The atwood furnace quit igniting on our last camping trip. The fan (blower) will come on and run for 30 seconds and shut off, (no ignition no heat). Propane tank full, batteries charged, connected to land power but still no change.
Any thoughts are welcome
Thx
  • 3_tons's avatar
    3_tons
    Explorer III
    I had a similar problem, and after examination it was not the sail switch... Turned out that theres an ignition prover (not sure if thats the proper OEM name) just above the exhaust outlet that has two electrode prongs, that over a time the gap can get outta spec due to road vibration... I pulled this out and closed the gap a bit (to about 1/4”) and all was well again... Haven't had a single recurrence in over 5 years since...
  • Mike63376 wrote:
    Got the same sail switch problem. 2019 jayco. Atwood furnace gas valve won’t open. Shut it down. Removed cover (no door). Tapped on sail switch lightly. Reset and powered thermostat. Works fine for about 3 weeks. Just happened again. Do I have to remove the whole furnace to change sail switch. It has the new design. Bought another new furnace. It has the old design sail switch. What’s the problem with the sail switch. Jayco is new. New sail switch is located in blower outlet housing, old style is in combustion blower housing. Why the change in locations?
    One sail switch problem many Escape Fiberglass trailer owners have been having with the Atwood AFSAD12 furnace is pet hair jamming the switch. Rather than replacing it, carefully removing the accumulation has fixed it.
    The newer installations include an outside door that provides access to both the electronics & sail switch. Older models require pulling the furnace for either.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
