Old-Biscuit
Mar 17, 2013Explorer III
Typically IF blower is shutting down at same time burner shuts off it is either due to bad/incorrect wiring or faulty relay.
You have a new Dinosaur board (with relay) so the board should be good
You stated that:
5. My programmable thermostat loses all of it's programming, time, date etc.
I think your problem is the t-stat and/or wiring from t-stat to circuit board.
Could be the relay connections on board or connectors for power to board but I would check wiring/terminals on t-stat and to board.
You stated that:
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
