gotsmart
Mar 18, 2013Explorer
If everything else is good and the consensus is the t-stat, I'll throw this into the mix:
Could it be that the make and model of the t-stat you are using does not perform well in an RV environment?
Why do I ask that? I owned a S&B house in NH with FHA heat. Without a humidifier on the furnace, static electricity was a problem throughout the house in the winter. When I went to replace the old round dial t-stat with a setback t-stat I bought a Hunter (brand) t-stat for something like $39. I don't recall the model #. The tiniest static discharge from a finger touching its control surface would erase all of the programming that I did. I returned it and bought a Honeywell CT3400 setback t-stat for $99. At the time I thought $100 was too much for a t-stat. IIRC, it was advertised as resistent to static electricity. It is. I would drag my feet on the carpet, touch it, and generate huge - mildly painful - shocks and nothing hapened to the t-stat.
Where am I going with this? If you replace it with an 'old fashioned' t-stat, similar to one of these, and the furnance works fine - then research the available t-stats. Test 2 or 3 of them. Look for a ruggedized unit designed for hostile environments. It just may be that the one you bought sucks, or is not well suited for the application that you are using it for.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
