obscenic
Mar 21, 2013Explorer
Ok, I was wrong about the t-stat. Jump starting it by directly connecting the t-stat lines also causes the board to shut down the fan on a failed ignition. No purge cycle, no power to the board.
I'm out of ideas. The relay is working perfectly, the board is new enough that unless it's a dud, it's not a consideration, the t-stat has been ruled out, the ignition gap is fine...
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
