obscenic
Jan 07, 2014Explorer
So... the saga continues.
I replaced the furnace. I thought with the frequency with which I use it that I could afford reliability. I put in a new 7916-II from atwood, and it works much better, but:
Once in about 3 times trying to start, the t-stat STILL shuts down during the ignition attempt, causing a failed ignition (because it opens the switch which closes the gas valve etc) and starting the whole startup cycle all over again 2 seconds later. This means the furnace will sometimes go through 3, 4, or 5 startup cycles before it actually starts burning gas and producing heat.
I'm at a loss now. The wiring is brand new, the t-stat is brand new (with fresh batteries), and the furnace is brand new. Are programmable thermostats just incompatible with RV furnaces?
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
