obscenic's avatar
obscenic
Atwood furnace shuts down after first failed ignition
Furnace: Atwood hydroflame 7912. Probably a 1983. The board has been replaced with a dinosaur board with fan control.
I have a very bizzare problem, that I'm hoping someone out there might have some ideas about. I've spoken at length to technicians from dinosaur boards about it with no outcomes. Here is what happens.
My furnace will run fine for many days, through many cycles. Then, with no changes to anything else (usually in the middle of the night or early morning) the following happens:
1. Thermostat turns on
2. Fan turns on + sail switch engages
3. Propane valve opens and igniter strikes
4. Furnace immediately shuts down and turns fan off
5. My programmable thermostat loses all of it's programming, time, date etc.
...There are no re-try attempts (there should be 3)
6. The furnace will remain off until the thermostat is turned off altogether for at least 60 seconds. Then there is a barely audible click and I can try again to turn the thermostat on.
7. Turning the thermostat on causes the exact same thing to happen.
To workaround this, each time this happens I remove the ignitor, blow air into the combustion chamber to clear out the propane build-up, reinstall the ignitor, turn the thermostat on, and it ignites just fine.
It seems at first glance as if there's two issues at play here (1. failure to ignite and 2. immediate shutdown) but I'm not totally sure it is two separate issues. I think if the blower wheel was allowed to run (as it is supposed to after a failed ignition) and clear out the propane it would probably ignite the second time.
  • Maybe its the thermostat. Do you have a analog one you can try? if not I have the old one from my unit I can give you (I'm in Calgary)
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
