time2roll
Apr 16, 2018Nomad
The expansion tank/accumulator will act same as the air pocket and absorb the increased volume/pressure and avoiding the spike that would otherwise be created by the expanding water. Can be installed anywhere between the pump and water heater. Basically it is a permanent air pocket.
I had an issue a decade ago where the spike in pressure was causing a leak at the pump. Very hard to detect due to the intermittent nature. Dealer failed twice to find the leak.
And yes I did notice a spike in pressure when the hot water was used up and then no water was used while it re-heated and expanded. This is when I realized the issue and found the leak.
I had an apartment building doing the same thing except it has 2x 100 gallon water heaters. I was having leaks soon after the water company required a backflow device on the main water supply. My plumber put a 2 gallon expansion tank on each water heater and the issue stopped. Leak under the slab was costing $4,000+ each time.
I recommend an expansion tank for all closed water systems including your home or the RV. It really works.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
