drsteve
Apr 16, 2018Explorer
dougrainer wrote:
You need to order from an Atwood supplier a Part Number 32397 updated door gasket. Atwood had a problem with the original door gaskets and this seals better. Doug
This would suggest that Atwood is at least partly responsible for the OP's water intrusion issue, since they admit that their original gasket was inadequate. If water running down the wall from the slide rail was going in, I would expect that any rainwater running down the wall would do the same.
I would contact Atwood about this problem.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
