oldtrojan66's avatar
oldtrojan66
Atwood furnace
I have a problem that doesn’t seem to be directly addressed here.
My furnace will ignite normally and run for 10 - 45 sec n shut off. The blower continues to run and flame will reignite after about 10sec. May run for 10sec, or 20: but shuts off again. Flame has not run for even a solid minute since this began. We are trying to keep from winterizing before we head south at the end of the month. Filled propane tank yesterday, but problem began before than. Have two tanks and switched to B when I thought A was nearly empty. Same issue on both tanks. Any ideas?
Thanks in advance, David
  • will the stove light? might need to bleed off some air
    you might also need to clean the exhaust- I had the same issue with mine and cleaning did it.
    I would also checked all the connections
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
