I'm a little frustrated with my Atwood furnace. I have a 2018 5th wheel that I bought at the RV show in Sacramento. I hit the road to Arizona and almost immediately had trouble with the furnace. Fo...
That is one possible cause of Short Cycling.. Another is thermostat placement relative to the heat vents.. The T-Stat quickly heats as the furnace blows on it then shuts down then cools down and tries again. Annoying true.
ON my RV the original T-Stat was the front A/C. the sensor is actually in the grill assembly.. Well it tended to be influenced by "Cold" leaking in from outside. I had to put a fan on it to control temp.
Today the T-stat is in the hall, away from heat vents and The A/C.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
