I'm a little frustrated with my Atwood furnace. I have a 2018 5th wheel that I bought at the RV show in Sacramento. I hit the road to Arizona and almost immediately had trouble with the furnace. Fo...
Old-Biscuit said in my Atwood: (see link in my post after the OP)
"Mid...2 White Wires going into motor cover....Sail Switch, when it closes the DC from Sail Switch goes to High Temp Limit Switch and then to circuit bd via connector"
In the OP you said after they changed the main board it worked for a year until they changed the sail switch.
So the suspect would be the wiring they did for the sail switch?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
