jbrack's avatar
jbrack
Atwood Furnace
I'm a little frustrated with my Atwood furnace. I have a 2018 5th wheel that I bought at the RV show in Sacramento. I hit the road to Arizona and almost immediately had trouble with the furnace. For example, if the temp was 60" inside the coach and I set the thermostat on 70", the furnace would come on and cook for about 5 minutes and then the burner would shut off. The fan was still blowing and then in about a minute, the burner would fire back up. It would cycle on and off like this until if reached the desired 70". I took it in to a mechanic in Tucson and they replaced the circuit board. About 10-12 months later, the fan when I wanted heat, the fan would come on but the burner would not light. I took it in again (Camping World in Vacaville, CA) and they replace the Sail Switch. Now it lights right away but is back to that cycling operation from before. I called Dometic who took over Atwood, and they can't help me. They said I just need to take it back to a mechanic. My furnace is accessed through the storage compartment or basement. Each time I have to remove all of my gear and take down the walls so the guy can crawl in there. It's a royal pain the butt. Anyone have a guess why its cycling like this? None of the mechanics seems to know.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
