dougrainer
Feb 08, 2022Nomad
IF you have access to the back of the water heater you could possibly cut out the Styrofoam. BUT, most installations give no real access inside the RV to cut it out. Just enough access to disconnect the water lines. When you remove a burst water heater and you have not had access to the strofoam, the burst part of the inner tank protrudes up and out and will push the styrofoam up and cause the styrofoam to stop the W/H from pulling out of the mount hole. Since you are usually replacing the Inner tank and the new tank comes with Styrofoam and mount rings, you don't care that you have to manhandle and destroy the styrofoam when removing. You sometimes have to use a pry bar to get the W/H out once you have moved it a few inches. I would think the cost of welding the Aluminum tank would kind of negate the cost to a replacement tank that has all the parts included. Doug
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
