j-d
Feb 10, 2015Explorer II
Depending on how it's plumbed for winterization, your water heater could have a Check Valve on the hot water discharge side. That valve could have fallen apart. Since it's a Winnebago product, you should be able to look up a parts breakdown on the web and see if it uses a check valve.
This is a brass one from Camco sold as Amazon Prime "add-on item" for under $5. Notice the directional flow arrows stamped into it.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
