Old-Biscuit
Aug 31, 2019Explorer III
1st off
*Check if the Thermal High Temp Switch on burner Stack is tripped
Should be a Yellow & WHite wires on switch ----12VDC + from circuit board/back to circuit board (J15-1 & J15-2 terminals)
*Verify that the outlet fridge is plugged into actually works
*Got AC at outlet....then need to verify that the 3A fuse on circuit board has AC Voltage both sides of fuse
Can you swap from Auto Mode to AC Manual?
Does element get hot?
Can you swap from Auto to GAS Manual?
Does Flame ignite/stay lit?
Atwood did have 'issues' with the control board ---some folks had to have it chnged out 3X
Unfortunately....parts unavailable now
Atwood HE Models...2012 thru 2016 then discontinued when Dometic acquired Atwood.
Revised HE Manual
Revised HE Manual
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
