Dusty_R
Apr 25, 2020Explorer
It's been a while sense this has been discussed, and I hope my memory is right.
Most al shower head valves drizzle when turned off. If the hose comes out of the top of the mixing valves, the water is hot when turned back on.
If the hose comes out of the bottom of the mixing valves, then the water will be cold when turned back on.
I have found a way to fix this problem.
I installed a garden hose at the shower head, which does not allow the water to drizzle when turned off. The water may cool slightly when turned off.
In order to install the garden hose valve, you need to get garden hose to 1/2" pipe adaptors. I've found that the nylon ones work the best. I found them at Tractors Supply, in their farm sprayer supply area.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
