2_many_2
Apr 25, 2020Explorer III
Old-Biscuit wrote:Mike134 wrote:Old-Biscuit wrote:
Mike134 wrote:
Maybe you mis-read my post. What you describe is exactly what I had - a shower head with an on/off button. Despite this, when turned back on it was all hot for a few seconds. So it wasn't that I had to readjust the valves - they were already adjusted. I am just thankful it wasn't my son that got burned.
My shower head with the push button does the same thing. Not sure how the water remains circulating but it's just a straight hot water blast till the tempered water mixes in a few seconds later. Must be a design flaw since we both have had that happen
______________________________________________________________________
When you stop/limit flow thru shower head using the on/off button/lever on the handle the shower faucet acts like a mixing chamber.....
Hot water typically is at a higher pressure then the cold water due to pressure increase in WH tank from heating the water (it swells when heated/pressure increases from the swelling)
So when you turn shower head back on...hot water flows first until mixing of hot/cold in faucet catches back up with previous adjustment of knobs.
Simple thermal dynamics .......
Simple 'cure' ---- turn shower head away from you when first turning it back on via shutoff on handle.
Slow learners may require getting hit with that hot water a couple of times but should come to remember to turn head away initially.
I appreciate the explanation about the thermal dynamics makes sense.
To bad the rest of your answer shows you to be an a**h**e
Tisk tisk....not nice to call people names
But if you are one of those slow learners I guess it is the best you can do
:B I was one of those slow learners almost twenty years ago. It took me about three times to get the idea!
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
