Old-Biscuit
Jun 19, 2019Explorer III
Better solution
Use the NYLON OEM drain plug
Atwood uses the NYLON for a few reasons
NYLON will not strip out the Aluminum Threads (tank is aluminum and so are all threads)
NYLON has the proper temp/pressure ratings should the T-stat/ECO fail
NYLON seals without having to really crank on it with a wrench
Actually should install finger tight then using a 6 point socket just snug it up
Socket should be 7/8" (some are 15/16")
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
