dpgllg
Jun 19, 2019Explorer
CloudDriver wrote:
Here's what I did to make draining the water heater easy. Two nylon thread to barb adapter fittings, 12" of 1/2 inch tubing and a valve.
Stored position so door can close.
OP here
Will the plastic hold up to the heat of the hot water? What kind of fitting did you use to connect the hose to the hot water tank?
Thanks!
Dave
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
