opnspaces
Jun 21, 2019Navigator III
How I've always done it for last 14 years with same plastic plug. Put a 7/8" socket on the plastic plug. Put the tip of a 6 inch extension in the end of the socket. (it won't snap in but it works) Remove the plug.
I think most people probably way over tighten the nylon drain plug. Reinstall hand tight using just the socket and extension no ratchet handle. Put ratchet in extension and turn maybe 1/16th of a turn, that's it. If you marked the socket at the 12 o'clock position and turned to 1 o'clock you turned it too far. It really doesn't take much to stop the water from leaking under pressure.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
