dpgllgExplorerJun 19, 2019Atwood Hot water heater drain plugHello, My 5th wheel has an Atwood hot water heater that came with a nylon (plastic) drain plug. The location of the plug makes it very difficult to get a wrench or anything on it to remove the plug...Show More
LynnmorExplorer IIJun 22, 2019wa8yxm wrote:NOte about brass or steel plugs or nipples.... There is a reason Atwood put in a nylon plug.. Corrosion. Non alike metals corrode.Why then do they use these?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
Related ContentAtwood water heater problemAtwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???atwood GHC6A-10E water heater
