dougrainer
Jun 22, 2019Nomad
Lynnmor wrote:wa8yxm wrote:
NOte about brass or steel plugs or nipples.... There is a reason Atwood put in a nylon plug.. Corrosion. Non alike metals corrode.
Why then do they use these?
1. They are NOT a common removable part and NOTE the Teflon on the threads
2. NON Nylon plugs GAUL(seize) when dissimiliar metals are secured.
3. The drain plugs are supposed to be removed numerous times during the year to drain and also to winterize. Doug
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
