mobeewan
Jun 22, 2019Explorer
The reason Atwood uses nylon plugs is because the threads of the tank drain hole are aluminum. If you're not careful what you're doing you can easily damaged the threads when screwing in any metal fittings. Since this is something that has to be removed frequently Atwood provided plastic plugs as well as the ability to get plastic replacement plugs.
As previously noted, the overpressure temperature relief valve is bronze. Also the gas control valve is non aluminum and it screws into a hole in the side of the tank. It also has a copper probe that inserts into the tank. A little bit of Teflon tape is not going to do anything to electrically isolate any of these fittings from the threads in the tank. Although galvanic corrosion can occur between different metals, it occurs to different degrees with different metals when reacting with aluminum, steel being the worst with Brass and bronze at a lower degree. If Atwood was really worried about corrosion between the bronze relief valve and aluminum tank they would have provided something different than a sacrificial inner lining.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
