Old-Biscuit
Apr 11, 2014Explorer III
No hot water on electric or gas is pretty vague description of problem.
When you turn switch ON (electric or gas) does the 'red light' on panel light up after a few seconds?
When trying to light on gas does it even spark?
When you say "All fuses and breakers look good". What does that mean....di you just look OR did you turn AC breaker OFF then back ON to make sure it wasn't tripped? Did you locate the correct 12V DC fuse for water heater did you test that 12V was on both sides of fuse. Simple 12V Light tested can be used. Better if you have a meter and learn to use it.
Did you pull connector on module (in outside compartment) and make sure the contacts are clean and making good contact (use a pencil eraser to clean contact surface on module)?
Tell us what it does & doesn't do when trying to use it.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
