EMPIRE_LI
Apr 11, 2014Explorer
Ok the lights on the control panel work as normal the gas light comes on and stays on however nothing happens at the heater no gas and no flame. The electric light comes on and stays on however nothing is happening at the heater two days ago I replaced the pressure relief valve water was pouring out all over the heater. After this the heater worked as normal although since I'm on electric I did not try the gas side when we return home and have time I plane to pull all connections and clean them. I looked in my fuse panel for a blown fuse but found no blown fuses. Is it possible that the circuit board got so wet that it is blown?
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
