Old-Biscuit
Jun 27, 2014Explorer III
The only other things to check:
Gas pressure at furnace with at least 50% of other gas appliances ON....needs to be 11" WC (minimum pressure for furnace operation)
Bad flame sensing ire between electrode and circuit board.......it can supply the high voltage needed for ignition but if it is grounding or not making good contact the milli-volt flame proving signal can't get to circuit board.
Part number 33661....but may not be available any longer?
Circuit board.......pull and have it bench tested
Exhaust blocked
Gasket leaks
Heat exchanger warped/cracked
Exhaust blocked
Gasket leaks
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
