eq6352's avatar
eq6352
Atwood model 8531-Iv-dclp furnace
I have an Atwood 8531 furnance in my trailer and I just replaced the circuit board because it was bad. I am still not getting ignition when the unit comes on. What is the voltage supposed to be to the ignition probe? I am only getting between 7 and 9 volts. I am getting gas but it will not ignite.
  • Electrode is out of adjustment
    Electrode is faulty
    Electrode high tension wire is bad
    Bad or loose ground
    I suspect your electrode is bad
    Here is a service manual that covers your model......LINK
  • I am wondering why you replaced the circuit board? If you are measuring the voltage to the spark probe when it fires very low as the service manual lists that as a "high tension" lead and does not specify a voltage but it is in the 1000V or so range. They do advice not to attempt to measure it.
    I suggest that you download a copy of the service manual from the site of Bryant RV and study it.
  • I have 12.6V coming to the control board. The fan is running and the air flow is good. The LED on the control board is green until it tries to ignite. Then it turns red during the ignition cycle.
  • What is voltage where trailer wire goes into furnace?
    Is the fan turning/air flowing-- assume so since gas valve is opening?
