Oasisbob's avatar
Oasisbob
ATWOOD OVEN TROUBLESHOOTING ?
Pilot light lights fine. After two minutes I turn up the temp and burner comes on heating up. Then burner goes off and oven cools. Problem is burner will not relight . I see the pilot light get brighter but flames do not exit the burner. I thought the holes might be clogged but it lights off fine the first time. Any thoughts onb what to check?
  • Thanks Don. May I ask is the thermacouple or gas valve hard to replace?
  • Try replacing the thermalcouple first. If that does not do it, then replace the gas valve assembly. Thats the only two possibilities.
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
