WoodGlue
Apr 12, 2013Explorer
kckettridge wrote:
Our 2012 Coleman (Dutchmen) TT with an Atwood Range/Oven won't ignite using the igniter on the front of the range now. It worked the few times we had it out last year but when we went out last weekend and tried to light the stove burner and oven, it wouldn't work. I had to use a lighter. Has anyone else ran into this issue and if so, was it easily remedied without taking the rig in for service. Although it's still under warranty until June, our RV service centers in my area are booked out until June. If it's an easy fix, I would like to do it myself.
There may be too much of a gap between where the propane is and the Piezo. Sometimes, you need to let a little gas build up and then try to give it a click. If that doesn't help I don't think that on an Atwood Range that you can service this if it is indeed the problem. I could be wrong! LOL
WoodGlue
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
