64aggie's avatar
64aggie
Atwood RV Furnace will not start after changing propane cyl
I recently changed over to the reserve cylinder when I had the other 30 lb. propane cylinder refilled. Now my furnace, Atwood Hydro Flame 8531-IV-DCLP, will not start. When I turn it on, using the thermostat, nothing happens. The blower does not run as it normally did prior to the furnace lighting. I have tried switching cylinders. My Atwood Hot Water heater is working & I can use the Atwood propane range.
I have 12.4 volts through the off/on switch & the circuit breaker. The fan will run if I jumper this to the motor. There is also 12 volts from the thermostat and the ground wires all check out.
All web troubleshooting articles refer to a "relay" with four terminals. My unit does not have this, only the circuit board. Where is this relay? Also I get no light or flashes of the circuit board LED.
Any and all help is greatly appreciated. Thanks!
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
