eHoefler
Jan 07, 2013Explorer II
Check and make sure the propane cylinder has propane first. Then see if you can get the stove to light. If not, close the propane valve, remove the hose. Re-install the hose, slowly open the valve. Opening the valve to quickly can trip the OPD, ( Overflow Protection Device ) causing no flow of gas. Go back and light the stove, this may take a bit of time to bleed any air from the lines. Use a match or one of those butane lighters instead of the ignitor on the stove. When you get a solid steady flame, try the furnace. It should light, it may take a couple of tries to bleed any air.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
