Stephlm04's avatar
Stephlm04
Atwood RV furnace
We have an atwood furnace. Was working fine until our last night of camping. It just stopped working. We did not run out of propane. Now we click the reset button on, furnace works fine. But once we turn reset button off...everything to do with the furnace turns off right away.
  • Welcome to the forums Stephim04, we hope you can learn a little and hopefully teach us old folks a little. As noted, your question left us with more questions than answers, it is helpful if we really know what you are talking about, you provided us with a manufacturer but not a model, we don't know what year the heater was made or what thermostat connected to the heater.
    It's also helpful to know a little about your rig, age, make, model, size and if you have any of the manuals provided by the RV manufacturer.
    I'm going to assume that the reset button you're referring to is actually an on/off switch on the thermostat and not a reset switch. You can tell by our confusion that this is something new to us.
    Normal operation is the thermostat is set to heat, turned on and the temperature is set to desired level. If everything works as intended, when the temp drops below the setting on the thermostat, the fan starts, when it reaches a predetermined speed it closes a switch called a sail switch. When the sail switch closes, propane is allowed to flow and an ignitor starts clicking and ignites the gas.
    When the desired temp is met, the gas is shut off by the control board and the fans runs for awhile longer and cools off the heater.
    When the temp drops, it goes through the same on/off routine until you turn it off using the switch on the thermostat.
    A lot of us had the old round dial type thermostats that were not very accurate and we change them out for digital thermostats used in homes.
    As you can understand, "The devil is in the details" and you didn't give us a lot of details.
    Don't be discouraged, we want to help and collectively we're smarter than most manufacturer techs. We do have the answer you're looking for.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    The furnace is an energy hog. not only does it burn propane to heat the air but it burns Battery power to move the air around.. When the batteries start to run down then the blower can't blow hard enough to sail the sail switch and the furnace quits.
    Let the batteries charge a bit and it works.. till you turn it off that is.
    NOTE: I am not sure what you mean by "RESET" switch.. the Furnace has only two switches (normally, mine now has 3) One is the thermostat (I will exlain mine) one on the furnace. the one on the furnace is also a circuit breaker and thus a "Reset" switch, but like your 120 volt breakers must be ON for it to work.
    Now the T-Stat may have a Reset on it, but that is for the T-Stat not the furnace There may also be a heat/off/cool switch, turning it off, then back on,m will often reset the furnace as well.
    Why do I have 3 switches.. Well when I had to re-do my thermostat I got a chea one (The thermostat is itself a switch by the way) so since I used a cheap T-Stat, cheapest I could find.. I put an ON/OFF switch beside it.
  • Why would you turn the reset button OFF?????? It is supposed to be ON. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
