Old-Biscuit
Jun 01, 2013Explorer III
Here is the deal......
Suburban use anode rods because they are porcelain lined steel tank and will rapidly deteriorate with out the use of a sacrificial rod.
Atwood are aluminum alloy tanks and do not require an anode rod.
BUT over time even aluminum will erode....many, many years before it is a problem.
Aftermarket anode rods are available that fit in Atwood drains. Whether the anode rod is aluminum, magnesium or zinc the thread head & support rod are made of steel.
Screwing a steel threaded rod into an aluminum threaded tank can cause galvanic corrosion.......dissimilar metals....an anode & cathode.
Just because it's made and sold doesn't mean it's worthwhile or needed.
Your choice.
Your choice.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
