Old-Biscuit
Jun 07, 2015Explorer III
IF the T&P Relief Valve above is not weeping/dripping down then you have a crack in WH tank..most likely at the drain plug bung weld.
It can be repaired (re-welded) but will require complete disassemble of water heater components/pan/frame from WH tank to access area .
Don't know where you live........did you not drain/winterize WH tank and it froze?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
