theoldwizard1's avatar
theoldwizard1
Explorer II
Oct 08, 2016
Atwood water heater ECO and temperature thermostat
My daughter's family has a Jayco TT with an Atwood 6 gallon propane water heater. It has not worked properly since they purchased the trailer new about a year ago. They have had it back to the dealer 3 times without satisfaction (another story).
This unit has electronic (spark) ignition. After studying the diagrams I think I know what the problem is, but getting the correct part might be hard. Both the Emergency Cut OFF (ECO) and electronic water temperature switches (equivalent to the old fashioned mechanical thermocouple) have to be on for the burner to ignite. I don't think this is happening. The replacement pair from Atwood look a like and are not marked, so I assume they are identical.
I would like an ECO switch that is ON until the temperature is ABOVE 170F. If my understanding of the circuit operation is correct, the gas valve will stay closed until the water temperature switch calls for ignition and the gas valves to be open.
Does anyone know where I can buy a high temp ECO shut off switch that would work withe the Atwood water heater ?
  • OK.....
    ECO opening is a real long shot.
    If it was opening early it would continue to do so.
    2 nights of use and 1 non-relight.
    That could be spark electrode position....has to be directly in flame (tip should get RED) and gap set at 1/8"
    That could be ground issue.......either at spark electrode assembly (bracket/mount screw not tight/clean contact)
    That could be loose spade/terminal contact on t-stat/ECO
    That could be connector contact issue at circuit board
    That could be gas solenoid terminal/spade contact issue
    That could be a fluke
    Poor or corroded wire connections cause most of the intermittent problems in water heaters.
    And no grease or dielectric sprays etc.
    T-stat and ECO must make clean constant direct contact with tank wall.
    Terminals on the t-stat/ECO should not move and wire spade connectors should go on the terminals tight.
    1 non-fire is not a real issue.....if it continues to not fire up --- that is an issue
  • I don't think I have ever found a bad ECO. I do see the thermal fuse breaking down causing intermittent operation. If I have intermittent operation, I change the thermostat and ECO kit and the thermal fuse.
    Definitely RED and they paid $70 to have the service center "adjust" the position.
    All wires and connectors are NEW and appear to be clean. The Temp and ECO connectors have been cycled several times now. It wouldn't hurt if I removed and re-seated the circuit board connector.
    Let's hope that one time was a fluke !
  • Well, my daughter's family just got back from a 5 day trip. Water heater was non-functional most of the trip.
    They are talking about going to an instant water heater, but none of the residential gas models will fit and the electric ones require 240V (they have a 30A connection).
    They are concerned about their HOA so they don't want to keep it overnight so I can do more diagnosis.
