TravelingRae's avatar
TravelingRae
Atwood water heater heating to tepid then shuts off
Last night, I noticed that my Atwood water heater (electric ignition) wasn't lighting. I'd hit the ignition switch and nothing. The water was around 40C (104F). It was definitely getting power.
This morning, the water heater turned on like normal, heated to 40C, and shut off. I couldn't get it to relight until the temp went down several degrees.
This happened again tonight. I can't get the water above 40C, which is barely tepid or lukewarm, definitely not hot enough for washing dishes much less taking a shower. It normally goes to at least 46 or 47F (115F); hot enough to scald myself.
I put in a new circuit board three years ago and I do maintenance like cleaning the flue, checking the probe, and cleaning all contacts at least twice a year.
Any thoughts?
Thanks,
Rae
  • Hi Rae,
    If you have an ohm meter check them both. I don't know what the value should read, unfortunately.
    -fixed temperature control thermostat
    -thermal cut-off
    Chris Bryant maintains a web site for trouble shooting water heaters and is very helpful.
  • Mine doesn't have a temp switch as far as I know. The manual says "Electronic ignition: light unit by pushing button inside the coach. Water temperature is non-adjustable."
    I'm looking at the wiring diagram and there are a few temperature related parts on it:
    -thermal cut-off
    I should be looking at which one of these?
    Thank you so much for the quick reply!
    Rae
  • Hi,
    The high limit thermostat has failed or is out of adjustment (I do not know if they are adjustable or not).
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
