Lynnmor
Apr 15, 2018Explorer II
dougrainer wrote:Lynnmor wrote:
Yes, some noise from an electric heating element is normal. An increase in noise level can indicate a failing element.
A check valve is often installed with a winterizing system that has the one valve method.
Heating Elements do NOT make any noise. What makes you state such a thing? Doug
I have had electric water heaters nearly all of my life, they DO make noise. While some say it is the buildup of scale on the element, I have had noise from brand new elements, and with my water there is no buildup anyway. Google: "electric water heater hissing noise"
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
