BillL1356
Oct 05, 2015Explorer
Check to see if is in the flame. I had a similar or the same problem and I found that the igniter was positioned too high and off to the right not only did it continue to click but because it didn't get hot enough it kicked off the heater. The fix was simple. I adjusted the position of the igniter using a pair of needle nose pliers and a little trial and error.
Bill
Bill
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
