Chris_Bryant
Mar 09, 2018Explorer II
The 12 volt power goes from the switch through a flame fuse, thermostat, then to the ignition module. Any of these can interrupt the power- a meter or test light will tell you where the power stops.
Those flame fuses are flaky, but all of them, including just a bit of corrosion on the board connector, can give that failure- power not getting to the board, since you get no fault light.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
