Dutch_12078
Mar 09, 2018Explorer III
If you have a common LP furnace like the Hydroflame 8500 or 8900 series, the igniter board is usually easy to remove and can be used as a substitute for the water heater igniter board for diagnostic purposes. It will work fine with just the same ~20 second delay that the furnace uses before it kicks in.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
